5,00 Stern(e) 59 Votes
meierchen006
Hallo @caruso56
OK, meine Software ist neuer.
anbei meine Eingaben im "CODE EDITOR" evtl. hilft dir das weiter:
Code:
type: entities
entities:
  - entity: sensor.myhome_ah56_circuit_0_state
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_current_power
  - entity: sensor.myhome_ah56_circuit_0_current_flow_temperature
  - entity: sensor.myhome_ah56_heating_energy_efficiency
    name: Tages Arbeitszahl WW & Heizen
  - entity: sensor.myhome_ah56_outdoor_temperature
    name: Outdoor Temperature
  - entity: sensor.myhome_ah56_zone_1_circuit_0_current_temperature
  - entity: sensor.myhome_ah56_zone_1_circuit_0_humidity
  - entity: sensor.myhome_ah56_circuit_0_heating_curve
  - entity: sensor.myhome_ah56_system_water_pressure
    name: System Wasserdruck
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_on_off_cycles
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_operation_time
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_consumed_electrical_energy_domestic_hot_water
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_earned_environment_energy_domestic_hot_water
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_heat_generated_domestic_hot_water
    name: Wärmeerzeugtes Brauchwasser
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_consumed_electrical_energy_heating
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_earned_environment_energy_heating
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_heat_generated_heating
  - entity: binary_sensor.myhome_ah56_trouble_codes
title: MyHome-AH56 / [URL_INTERNA=https://www.hausbau-forum.de/threads/vaillant-erfahrungen-arotherm-plus-vwl-35-55-75.42822/]Arotherm[/URL_INTERNA] plus 55/6
state_color: true
caruso56
Hast du mal nachgefragt ob du ein Update haben kannst von Vaillant? wegen des Fehlerhaften Integrals?
Ja, bei meinem Heizungsbauer. Bis jetzt noch keine Antwort. Der Vaillant Techniker kommt am Freitag zur Vaillant-Inbetriebnahme. Vielleicht weiß ich danach mehr. Es braucht wohl eine neue Platine. Updates per Einspielen (Kabel oder OTA) gibt es scheinbar nicht.
meierchen006
Ja so ist es, kann kaum jemand verstehen dass es so ist. Trotzdem solltest du darauf bestehen.
Übrigens mit dem ebus werde ich mich demnächst auch noch beschäftigen wollen erstmal nur auslesen von Daten, später evtl. mehr mal sehen.
Ich hätte gerne noch die Rücklauftemperatur des Heizungssystems, sofern es dafür einen Fühler/Sensor gibt.
Wann ging deine aroTherm plus in Betrieb?
meine Daten bis eben 16:30 Uhr
Zuletzt aktualisiert 02.08.2025
Im Forum Vaillant Deutschland GmbH & Co. KG gibt es 51 Themen mit insgesamt 6731 Beiträgen
1Wärmepumpe-Planung Reihenendhaus aroTHERM plus 55/6 oder 75/6 141
2Arotherm Plus / Homeassistant EBUSD - Seite 4178
3Kaufberatung, Vergleich Wärmepumpe: Daikin oder Vaillant? 19
4Vaillant Luft-Wasser-Wärmepumpe - Angebot gerechtfertigt oder nicht? 18
5Vaillant VWL 125/6 A Luft-Wasser Wärmepumpe Erfahrungsaustausch - Seite 317
6Wärmepumpe Vaillant aroTHERM Split VWL 125/5 AS 400V S2 + VWL 127/5 IS 21
7Vaillant recoVAIR Lüftungsanlage - Erfahrungen? - Seite 12123
8Hydraulikschema f. 2 Fußbodenheizkreis Vaillant Arotherm Tower gesucht 42
9Vaillant flexotherm exclusiv Wärmepumpe einstellen 15
10Kosten Wartung Vaillant Therm plus VWL 75/6 A Höhe ok? - Seite 320
11Vaillant Recovair - Was vor der Installation beachten? - Seite 216
12Vaillant flexotherm - empfehlenswert? 26
13Vaillant Kontrollierte-Wohnraumlüftung - Bericht Planer Auslegung 13
14Kontrollierte-Wohnraumlüftung & Wärmepumpe: Viessmann vs. Vaillant vs. Zehnder? 47
15Vaillant Luft-Wasser-Wärmepumpe - Welche könnt ihr empfehlen? - Seite 316
16Neubau - Fußbodenheizung ungleich heiß (Vaillant aurocompact) - Seite 212
17Wärmepumpe für Neubau-Einfamilienhaus Effizienzhaus 55 12
18Planung Heiz- und Lüftungstechnik KfW 40-Plus Einfamilienhaus - Seite 665
19Luft-Wasser-Wärmepumpe Stiebel Eltron Kosten von 34.000 €. Preis angemessen? - Seite 325
20Senkung der Vorlauftemperatur bei Fussbodenheizung komplexer als gedacht? - Seite 370
