Which acid-free cement residue remover?
  • Erstellt am 2020-03-06 17:21:33
Golfi90
2020-03-06 17:21:33
  • #1
Hello everyone!
Which ACID-FREE cement residue remover can you recommend to clean newly laid tiles?
I am looking forward to your recommendations!
Katdreas
2020-03-07 00:38:25
  • #2
I just also have a [Zemenschlierenentferner] from the hardware store at the construction site and I don’t dare to use it... I’ve read a lot about it online and talked to tilers and tile dealers. It’s supposed to be the only thing that helps
KlaRa
2020-03-12 13:08:15
  • #3
While lumps of mortar can be chipped away, a "veil" is known to be only a thinly dried film. Naturally, it is alkaline and therefore can primarily be removed only with acidic cleaning agents. If you are afraid of chemicals, you should, for example, stay away from COLA. Holding a litmus paper in the drink shows a pH of 1 (strongly acidic). So take (this is meant seriously) a bottle of COLA, pour it over the affected area, wait about 10 minutes, and then wipe up the grime with a cloth. Rinse with clear water, and you will see: the cement veil is gone! Regards: KlaRa
